NIC help?
Can't sem to get new build nic to show gigabit on router.
MB-MSI-  http://www.msi.com/product/mb/FM2-A75MA-E35.html
router- Netgear- http://www.netgear.com/home/products/wirelessrouters/work-and-play/WNR3500L.aspx#
I pulled a working system off this line so nothing changed but the new pc. Router and cable are the same and they were working gigabit when disconnected from the old pc. But I only disconnected one end and havececke cable since. I am pretty sur I hve th llllltest drives so  am stumpd.Ay help would be gratful Thanks
What order did you download the drivers in? Uninstall and reinstall you LAN drivers.
thanks. that did it
