I have an issue when one of our sister servers was retired. That server in the federation share settings of our current server was un-trusted and the federation app removed. In the logs, we are getting these connections errors. We are also experiencing 30-60 second populate times of our files when using nextcloud. I think these connection attempts is the cause for that slowness. I would like the system to stop trying to connect to this address but I am unsure where is is still located in the system. Any help would be appreciated.
Nextcloud AIO v7.7.1 with ClamAV and Collabora
nextcloud version 27.1.4
php occ config:list | less (or equivalent) may show the setting you are looking for. Just /appname or /domainname once less has started. q will exit less.
seems the general fix was “I have this same problem. I had to remove my federation add folder.” it looked like they removed the folder and the share to it.
