UHBR20 KVM… at least 2 monitors and 4 hosts? Pwetty Pweeze!!
We’re workin’ on it!
@Level1_Amber are those planned to support EDID emulation? or will they be functionally more or less equal to DP 1.4 KVMs?
For displayport? It’s dicey. The problem is that it introduces timing artifacts for freesync/gsync in displayport contexts. The standard is defined as leaving it to the host to cleanly handle, which is better, but the hosts don’t cleanly handle always.
There is no “actually” UHBR20 chipset right now thats full rate, only partial rate. The ones rated for full rate have failed testing when doing a full rate sweep even with insanely expensive gold 12 layer PCBs (for signal/noise isolation).
Thanks @wendell for the answer. I’m asking because currently I’m running yours HDMI 2.1 KVM(previously I had yours DP 1.4 model) and I’m in the process of upgrading my setup, was wondering if I should wait for DP 2.1 KVM, but if it lack EDID emulation then I’m sticking with HDMI one.
Btw, thanks for doing all the great work in such niche area, you’re life saver!
I heard about you and this forum on Reddit! Really cool info you’ve got on here. I’m using my desktop PC for higher-end gaming, and need to connect my work laptop to the same monitor. It’s an LG LG 49" Ultragear (5120x1440) ultrawide that I want to run at its native 240hz refresh rate with as minimal latency as possible, but I need a KVM switch to connect both computers to it, a USB-C mouse, a USB-A keyboard and headset base, a USB-C charging cable, and an audio cable with a 3.5mm jack to run speakers from.
I’ve looked everywhere and can’t figure out what the best solution for this is. Can you help me with some guidance? I’d appreciate any that you can give.
Are there any updates on this?
Same question here as well…
Is there an incoming DP 2.1 KVM with quad monitor incoming? If so, when could we expect it?
Would be awesome to include some type of earc extraction to have Dolby atmos and dts:x while using 80 gbps DisplayPort for refresh rate
