Some errors have been popping up during boot as well as when shutting down or restarting the computer. As far as I can tell stuff still works but if there’s any advice on how to address these errors that would be greatly appreciated.
Above is the JournalCTL for the last little bit of using the computer and below is the linux-hardware probe. I am running Debian 12, kernel 6.1.0-11-amd64 and use a 6700xt and 7950x as my machine.
Not sure what the latest kernel is that Debian supports, but 6.1 is relatively old considering how new 6700xt and 7950x are. I’d try one of these bleeding edge live distros before going custom kernel.
E.g. If you run a Fedora live image and upgrade that (sudo dnf update -y) you’d get a 6.4 kernel and maybe different content in the boot log. Depending on that outcome you can tackle the next step on your Debian system.
Nope. That won’t help. The live images are read-only and with some trickery allow modifying the root file system within limits (changes are kept in memory).
Removing iso files from the USB doesn’t help in this case.
Update: I just realize that the approach of updating to the latest kernel in a live image cannot work.
Even if you manage to update the kernel in the live image it will not persist and therefore you won’t be able to observe the bootlog of the updated kernel.
You can obviously take a look at the bootlog of the kernel that was shipped with the live image.
Unstable is great for many hobbyists but there are no guarantees your system will work. Do not run unstable on systems you need to be up and running with minimal downtime, unless you are certain you can handle the occasional hiccup and subsequent googling on Stack Overflow. Other than that Unstable is awesome.
Would you recommend maybe switching to another distro than? I don’t mind debian with KDE but if my hardware is a bit new for Debian 12 I’m down to switch to something like Nobara, maybe try Nix or something similar. I don’t know if I want to full on go to Arch since I prefer using my computer than troubleshooting it. I had been planning to do stuff with Pop!_OS but really want to wait for Cosmic now since it’s over a year old in its current release.
6.1 was released at the end of 2022. In your case I do not think it is a problem and the kernel should be good enough but just in case, here is how to enable a new kernel from backports (assuming you run Debian 12 bookworm);
echo deb http://deb.debian.org/debian bookworm-backports main contrib non-free | sudo tee /etc/apt/sources.list.d/bookworm-backports.list
sudo apt update
sudo apt install -t bookworm-backports linux-image-amd64
sudo apt install -t bookworm-backports firmware-linux
If this does not solve your problem, start a new thread with full dmesg output and we will start from there. Do link the thread from here. Sorry confused this thread with generic Linux problems thread carry on!
I got these warnings should I be worried or try to fix them or is that normal? Since that’s a lot of possible missing firmware for the gpu, though it’s a third party Radeon 6700XT so navi should be 2.2 I would have thought.
update-initramfs: Generating /boot/initrd.img-6.1.0-11-amd64
W: Possible missing firmware /lib/firmware/amdgpu/ip_discovery.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vega10_cap.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/sienna_cichlid_cap.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/navi12_cap.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/psp_13_0_11_ta.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/psp_13_0_11_toc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/psp_13_0_10_ta.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/psp_13_0_10_sos.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/aldebaran_cap.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_3_imu.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_4_rlc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_4_mec.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_4_me.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_4_pfp.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_3_rlc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_3_mec.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_3_me.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_3_pfp.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_0_toc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/sdma_6_0_3.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/sienna_cichlid_mes1.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/sienna_cichlid_mes.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/navi10_mes.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_4_mes1.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_4_mes_2.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_4_mes.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_3_mes1.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_3_mes_2.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_3_mes.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_2_mes_2.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_1_mes_2.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_0_mes_2.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/smu_13_0_10.bin for module amdgpu
Aha, so it seems like you need to replace non-free with non-free-firmware in the file /etc/apt/sources.list.d/bookworm-backports.list. Run apt-get update and voila.
For the edit don’t worry I have used the generic linux problems but felt that the mix of this being a during boot and shutdown issue alongside not currently stopping the computer from working meant it would be best served as it’s own post. If there are tips on when to post in the small linux problem thread vs making your own that would be greatly appreciated.
If you think you can narrow the warnings down to just relevant info then that is better, best is if you can copy paste the relevant parts and include full dmesg in a .txt file. Most of the time warnings are sufficient but sometimes full dmesg is required.
is there a good way to copy the entire dmesg to a file since dmesg by itself doesn’t do the very start and dmesg | less does it in pages that are not much easier to copy and paste all from.
