TLDR:
Read specs below in “New build, your help needed:”, advice needed on new NAS build for home entertainment by newbie to NAS’s building and operating but has hardware exp
I’m going to build a new NAS for my sitting room, the last Plex update on my QNAP Server (TS-453A) caused issues, seems the CPU seems to be the issue, my skew is no longer supported.
In fairness it has served me well and I’ve rolled back the server but that does not seem to have worked , I think wiping all the plex files might work but in reality its an old system so maybe its time to retire it to a security server and create something new.
I’ve been doing a little research, reading and so on over the last couple of weeks and gone through a few iterations, mainly due to the location I had initially intended for the NAS to go in (small area) which I’ve now scrapped.
But since between m-itx case restrictions and budget I’ve moved away from that, I’m now thinking (unless someone posts a good argument against it) of getting a cheaper ATX case, I’d like 6+ HDD’s, M.2 boot drive (unless there is any reason not to go there). I’m mostly going to be doing 2k streaming via Plex, some downloading via a torrent server and mostly that’s it, there will be some backing up of devices and so on but mostly Plex usage. Budget will be about €500 (£450) aprox (+/- 20%)
Corsair Obsidian 750D Case (buying 2nd hand, getting HDD 2 cages and will buy a 3rd new, as I read they are scarce and its in stock now)
Suggestion needed for motherboard (leaning in direction of MSI B460M-A-Pro, thoughts?)
Intel Core i5-10400
Noctua cooler (suggestions welcome)
16/32 Gig advice wanted here
Intel 660p M.2 512 GB (suggestions welcome)
500 power supply, looking for reliable but cheap, ideally modular (I can always want it all and compromise later )
I already have tones of HDD’s for it, most 4TB WD reds so all good here.
Questions:
Looking at unRAID, any hardware I need to avoid?
Any reason to go for 32 gig of ram?
Any reason I should include SSD’s in the build as well as the M.2?
1 or 2 Intel 660p 512GB M.2’s in raid? If 2, why? What is the benefit?
I’ve a APC by Schneider Electric, is there any reason why that cannot be sat on, below or around the NAS once built? I will want the NAS to be powered by it.
Oh, I am on another forum on this topic too and got a confusing response regarding the M.2 drive, is it useless in a NAS build? What should my boot drive be?
Thank you in advance
