I’m having a hard time to decide which motherboard to go with my new system setup. I’m considering the Gigabyte X570 Aorus Master, Asus ROG Strix X570-E Gaming, and Asus X570 Crosshair VIII Hero.
Here are my requirements:
two GPU passthrough ( one for win10 vm and one for macos vm)
two m.2 passthrough (one for win10 vm and one for macos vm)
on-board SATA controller passthrough (for FreeNAS vm)
Intel X550-T2 (pciex4) network card sr-iov passthrough (vf network interface for the vm)
usb3 controller passthrough
Which motherboard should I buy? Other motherboard I can also consider?
From those 3 boards i would say the Master probablly.
Because the Hero is simply too expensive for what it has to offer.
The Master has an overall better feature set over the E-strix i believe.
But yeah with that many devices to plugin, you might indeed want to consider Threadripper.
But of course that comes with a very hefty price.
But from those three boards, i would go with the Master.
Don’t you need another +4 for the NVMe devices? Normally one goes through the chipset and one goes throught the cpu, but that depends on the mobo. Also, maybe it doesn’t matter with PCIeV4?
I whipped one up on PC Partpicker just for fun. It wouldn’t let me add a second GPU. I wanted one AMD and one Nvidia which as I understand it, makes the PCIe passthrough easier with different IDs and such.
