New Rig, need help with Fan Connectors
(Posting in Building A PC and Cooling)
Here is the Mobo in question :http://tinyurl.com/kcnpnv6
Here is the cooler in question : http://tinyurl.com/m3aruyf
Here is a grand list of all part that will be in this build : http://amzn.com/w/CL2321L6IM0Y
(With the addition of two 100GB 2.5 5400rpm in raid 0, a 500GB 2.5 5400rpm  and an old card that is nvdidia 9800 i think.)
Basicly, I have done my homework and already have the RAM, The SSD and The Case, Case not being used and is being saved for this build.
But I will have these fans :
2 120m front intake
120mm bottom intake
PSU fan bottom (bottom in the out back?)
140mm side intake
120mm rear exhaust
240mm top liquid cooler exhaust
2 660 GPU exhaust
9800 exhaust
(can 3pins controll RPM?)
Basicly, A: Will all the parts work together? B: I want the intake on a channel that i can change, the exhaust on a channel that I can change and the CPU pump to be able to change.
Will I be able to change them with 2 3pins and 2 4pins (including cpu pump)? will 4 fans daisied on a channel be fine? And 1 fan and the 2 on radiator be fine on a 4pin? bit I still have the pump . . .
(I know the general basics of everything about building computers but fan set-ups . . . )
If someone can help me visualize the layout for all the fans with 2 3pins and 2 4pins that would help allot.
I know there are allot of questions but any help would be great, Thanks.
~EeveeA_
Full build link is broken :/
Sorry, give me a few and I will fix it.
Edit: Sorry it took soo long, fixed.
A: Yes, everything will work together.  However, that's a lot of ventilation; more than people usually need.  Also, the power supply isn't that great.
B. I'm not familiar with the NZXT fan controller, so I can't say.
I don't really understand what you're asking.  Clean up the english a little bit.
Have the radiator on top, and an exhaust fan at the back.  Put your intake fans on the bottom and front.
Make sure the case can support all these fans.
