New Graphics Card [Help]
so i am in the $100 Range, and I am deciding between a couple graphic cards,
1. http://www.newegg.com/Product/Product.aspx?Item=N82E16814130828 or http://www.newegg.com/Product/Product.aspx?Item=N82E16814130827  Does the super over clock matter on the first one? Video i used for refernce: http://www.youtube.com/watch?v=rdUdFep3vP0
2. http://www.newegg.com/Product/Product.aspx?Item=N82E16814130625
3. http://www.newegg.com/Product/Product.aspx?Item=N82E16814121652
i am going to buy a graphics card very soon and i need to know witch is the best for gameing and witch one should i go for
also the main reson for this graphics card is to stream, such games as league of ledgends and Minecraft
1. The super clock version has a little extra clocking speed(144Mhz) for an exta $20, so you have to decide yourself which one you want.
2. The GTX 650 super-clocked is better than the 550ti, so it's really up to you here. Try watching some gameplays and benchmarks between both the GTX 650 Super-Clocked and GTX 550ti, then make your decision from there.
