New cpu cooler
I'm thinking about getting a new cpu cooler for my Fx6300 and I've been looking at the cooler master hyper 212 evo, because it's only 30€ and I'm not going to overclock (maybe in the future). I just want a quiet cooler right now, so can someone tell me if the fan on the 212 evo is loud and if it is, do you have any suggestions for a quiet cooler? Because I'm not going to buy it if it's really loud. Atleast I would like something that's quieter than the stock cooler!
it says 31 db as loudest, it isn't exactly quit, but it's probably less loud than any graphics card you may have, as they run at about 38-47ish db under load.
if you want something reaaally quiet you're gonna have to get something like a noctua or be quiet! dark rock cooler.
I don't know how loud the 212 evo is, but Noctua are very quiet if you want to spend the money on them.
At the very least, a 212 will be quieter than the stock cooler. When I'm building with an AMD cpu I always buy a new cooler to go with it.
I had one of these installed before I upgraded to my new CPU and this this is a beast but it kept my CPU cool and wasn't loud.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118074
That cpu cooler looks to be really good, but when you read the reviews it looks like it's a pain in the ass to install it!
My graphics card is an asus gtx 760 and it's not loud at all, on full load the fans only go up to ~55% and I don't think that they are loud then. The amd stock cooler is much louder than my graphics card!
I've been looking at the Noctua NH-U12S but I would like something that is a little bit cheaper. But of what I've heard Noctua is the way to go if you want a really quiet system!
It was not fun to install but for an air cooler it worked awesome.
Yeah, on newegg almost everyone rated it as 5 eggs but everyone also wrote about the bad mounting system.
i've only used my dark rock pro 2. you cant hear it . i think they're releasing pro 3 soon though. you should check it out. looks kinda weird though( like something you'd fit into a car)
I'll check it out!
