Just built my new rig and it won't power on. The front panel power led is on and the sb_pwr green light is on but nothing. I've ensured the 8pin atx connector and 24pin mobo connector are secured in place. Since the power led and sb_pwr lights are on I'd assume I didn't receive a faulty mobo or psu but I'm not sure.
ive started the process of troubleshooting by trying to run it with one stick of ram installed but still no results. My specs are:
got the front panel connectors in correctly? those are easily the #1 problem. You can always short out the pins *sometimes board even has a jump for this, to see if it boots
Try only having the power switch connected, no other front panel connectors, could be an issue with the reset button connected wrong. If that doesn't work i'd try removing the system from the case and booting it externally in case of a short between the case and the motherboard. Are you CPU fan / case fans spinning ?
Your Motherboard should blink red on different places @ startup. when the red led stays on it means the component symbolized by the led is not working or not placed correctly.
Ok i think it's most likely a short somewhere. Try my previous sugestion, disconnect all front panel leads except the power button and see if that works, the suggestion below is worth checking about LED indicators too in case of a component issue, could be RAM not seated correctly for example.
Great news! The front panel connectors were messed up so i switched them around and it turned on. But I left the one stick in and the ram red led went on. I'm trying to plug everything back in and see if it works Right now. I'll come back if there's anymore problems. But if not, thank you and everyone else for the help!
No worries, glad you're up and running (ish) i not familiar with that board, but i'd suggest plugging all your RAM back in and using the MEMOK! button, it should sort any RAM issues or at least tell where the problem stick is.
