I just installed Windows 10 on my new system, and now I’m hearing this high-pitched sound out of nowhere. Could it be capacitor squeal or even coil whine? Not sure what either really sounds like, tbh.
Honestly, I probably wouldn’t have noticed if my PC were under the desk, but now I noticed it, and it’s annoying af.
The weird thing is, it only happens when the system is idle. As soon as I play a video on YouTube or run a benchmark in CPU-Z, the noise disappears. It also doesn’t get louder—it just fades in and out depending on the load.
Before putting everything in the case, I bench-tested the setup, and there was no noise… But yeah, my dumb ass was only checking the BIOS and didn’t install Windows back then.
Anyway, I pulled out the PSU and motherboard (no GPU installed) to track it down. I think it’s coming from the PSU, because it’s louder, but I also hear it around the motherboard
ports. Could it be that PSU noise somehow carries through the motherboard?
Not sure how normal this is or how I should judge this. I still could return it, but I kinda got it for a good deal. Any advice would be awesome!
The noise is now present even in the BIOS, and it started after I installed Windows. My gut says it’s the PSU, especially since the noise from that area is much louder. But I’m not sure if that’s a clear indicator. Is there a possibility that the noise from the PSU is audible through the MoBo ports? I’m planning to get an FSP Hydro PRI Ti to test what’s really going on. It would be a real pain if it turns out to be the motherboard, as I can’t return it anymore—I’d have to file a complaint instead.
Someone also suggested that the PSU might not store idle power properly.
Does it disappear if you turn off power management in UEFI (ASPM, lower C-states etc)?
I recently had a similar issue while running a lab mobo on my desk: it was pretty much silent until I enabled some power saving option and then it (the mobo) started to squeal rather alarmingly. Not in UEFI, only when idle in the OS - just moving the mouse pointer around was enough to make it disappear, but only while moving the mouse, it returned immediately when I stopped. An effect of rapidly turning power on and off to electronics on the mobo to save power perhaps?
To track down the source of noise a piece of tubing can be beneficial: put one end close to your ear and move the other end around to scan for the source!
