Never Going Back to Grounds
So, instead of grabbing a bag of my usual Steep&Brew Hazelnut coffee blend at the grocer, I bought a bag of the whole bean variety.  When I realized the mistake this morning, I groaned at the the extra effort, but took out my Magic Bullet and ground it like a boss (pretty sure I woke up my neighbors). I then swore to always double-check the labels from then on.
Well, I still intend to check the labels, but I won't be buying the pre-ground mix anymore.
How much better freshly ground coffee is is absolutely astounding.  Who knew that limiting the oxygen exposure by keeping the bean whole could make such a difference.  Wild!
If you want an even better brew, consider one of two options: an electric burr grinder or a mechanical burr grinder. If you are willing to put forth the effort, you can got by with something as simple as a decent pepper mill, just check the grinding mechanism to make sure that it is steel or ceramic, and you're golden. The grind is far more consistent and instead of having jagged and irregular pieces with dust, you have regular and rounded granules of coffee. If you want to take it even a step further, you could invest in a pour-over pot, which features a long and narrow spout, and also a filter holder for use either with an individual cup or a whole decanter's worth.
