So let’s start with the headliner. I have many problems as of now.
Steam, Teamviewer, Hamachi, Naming.
STEAM:>
I started Borderlands 2 yesterday, in order to play with a friend, the game starts, but when we are to connect to each other, there’s a connection problem, stating that one of us is using an earlier build of the game, steam don’t drop out different versions of the games depending on the OS it runs out of, I read up on it and it seems it’s a network device problem, I need to shut off all the devices I don’t use, and test again. So ipconfig…
NETWORK:>
enp5s0: (eth0)
ham0: (hamachi virtual network)
lo: (there is no place like home)
virbr0: (virtualbox? qemu? Virtual Network non the less.)
HAMACHI:>
Since we had problems with the network, I then installed hamachi, no front-end?! Terminal + Web browser in order to create a group. Really strange, but we created a group, both joined, we were on ‘the same’ network, started borderlands 2, changed the network settings to network, and voilá… Not found. We ended up just talking while playing separate.
Noticed today that I had two virtual networks, and I think that I recently set it up on VB, so I can just delete that there.
TEAMVIEWER:>
Next problem. I now don’t have any access on TeamViewer, which i used yesterday, it’s not logging in, stating that there isn’t any connection, so it’s probably using hamachi, which I don’t know how to disable.
ETH0:>
I also want to change enp5s0 to eth0, but I can’t find a systemd guide that I understand. Most guides suck, they state, do this, as if everyone knows what people are talking about. Bubbled devs.
DOUBLE STEAM:>
I installed steam, then I wanted to play HoMaM III HD, but it crashed, so I thought, OH, I can use lutris, STUPID IDEA. It installed steam again, this time a glitchy version that ended up crashing gnome for me. I forgot to set up timeshift, so I might have to re-install POP!_OS again. How do I uninstall the new steam installation?
