Have katkat 4.4 my Netflix keeps saying code 0013
Things I've done
Re install Netflix
Clear cashe
reset phone doing full recovery
Hard reset then restoring my data.
Things I've done
Re install Netflix
Clear cashe
https://help.netflix.com/en/node/13689
Did that last week, last option is to get a new phone. The software is bugged.
Thanks
try going to the Netflix web site then go into your profile then in the Your profile section select sign out of all devices then set the Netflix app back up on your phone.
Hope that works.
Not sure how you feel about it, but there are sites that keep old versions of apps. Maybe try a slightly older, stable version?
Thanks guys will look into that.
