Hello to all and all options are welcome and needed. Getting really confused on the which GPU to get would like advice on a high to middle end video card.. my understanding is that the right video card will lower my rendering time and the wrong one will increase so your help would greatly be appreciated
1st off these are the parts I already have http://pcpartpicker.com/p/3dio4
I will be using:
Sony Vegas 12, Adobe Premier, Aftereffects and Photoshop
I would also like to do a media share form this computer as well an possibly some HD Recording
Son might also do some gaming on this when he is home from college
What Adobe suite are you using? If you're using CC go with an AMD card because OpenCL acceleration is better than CUDA in CC, but in CS6 and below, it's not supported.
Vegas can use OpenCL acceleration as well, so again AMD cards will be better.
budget 400 but if the amount of time rendering will be decrease a lot i might go more but if there is little difference in time than i might go even lower and get more much needed hard drives
If you're planning on upgrading to CC any time in the future, then this card will be better. It's also better in Vegas - http://pcpartpicker.com/part/msi-video-card-r9280xgaming3g
If you're going to stick with CS6, then I'd get this card. But it is the worse of the two in Vegas - http://pcpartpicker.com/part/msi-video-card-n770tf2gd5oc
If you're not going to be doing any gaming, then it might be worth looking into workstation cards.
