Need some help with putting LEDs in my case
Ok, my question is, where would I plug this LED kit into on my PC?
Here is the hardware that I am going to get that concerns this question-
Fractal Design Define R4 Titanium Grey w/ window
Asus M5A99X EVO R2.0
Corsair CX 600W ATX12V
Mainly what I'm asking is where would I get power to my LED strip? I really want to take advantage of the large side panel window on my R4 to make my build look like it's on display... and really sexy.
I'm going to be using the extra expansion slot that is in a vertical position on my case to keep it away from my motherboard since I've read that the PCB on the LED kit is intrusive if you put it on the other expansion slots.
Thanks!
molex on the psu
It uses standard 4 pin molex.
I'm sure if you insulate the circuit boaed with some tape and take it off of the bracket, you could tuck it away somewhere out of sight
The LED kit comes with a bracket so it fits in expansion slots. If you look at the back of my case, you'll see a vertical expansion slot. I'm going to be mounting the LED bracket there- out of the way.
So the LED kit should come with a MOLEX adapter?
Molex will be fine.
