I am using Apple Music on my iPhone and just found out the downloaded Apple music songs on saved as M4A. My car audio system seems not recognizing this new audio format so I tried to convert the songs to MP3. However, everything I start the conversion, the apps returned an error immediately.
I tried 3 different audio converters with the same issue. How can I convert apple music to mp3 so I can play them on legacy audio devices.
If you subscribe to Apple Music, you can add music from the Apple Music catalog to your music library. Stream music that you’ve added over an internet connection. Or download music that you’ve added to listen to offline.
If you are interested in how to convert Apple music to MP3. Legitimate “converters” are not bypassing DRM in the traditional sense; they work by recording the audio as it plays.
Here’s the core issue if you are not allowed to convert Apple music to MP3: Apple Music subscription songs are protected by DRM (Digital Rights Management) . This is why you see .m4a or .m4p files. For subscription tracks, they’re essentially locked to the Apple ecosystem to prevent sharing.
When you try to convert Apple music to MP3 with a standard audio tool, the app sees the DRM and immediately fails the conversion . The Apple Music built-in conversion option also won’t work for these protected files. This is why you’ve tried three different apps and all of them have the same problem right away.
To convert Apple music to MP3, you need a tool that can handle the DRM by recording the audio as it plays . There are specialized paid converters for this, and some free versions exist, but they usually limit you to converting only the first minute of a song or have other restrictions.
You can also try a free and open-source audio recorder to record the music as it plays from your computer, which is a completely free method, although it is more manual.
OBS Studio is open-source software that supports convert apple music to mp3. Although it is primarily a screen recording tool, its audio capture feature allows you to record pure system audio, enabling you to convert Apple Music to MP3 with high audio quality without needing a paid conversion tool.
Open the software, then add an audio output capture source and select your system audio device. Start recording before playing an Apple Music song, stop recording once the song has finished playing, and finally use another program to export the captured audio as an MP3 file.
The sound quality of this recording method is far superior to other recording methods, but it requires manual operation and involves two separate steps: recording and format conversion. You can only use this method to listen offline to Apple Music songs that you legally own.
iMusicGo app is pretty good at this. You can download songs, albums and artists from Apple music to MP3. I have been doing this for months and it works good.
Audacity is an open-source audio recording application that can capture the sound played through your computer. By recording system audio in real time, it offers an alternative way to convert Apple Music to MP3 without relying on online services.
The software is available for both Windows and macOS and supports exporting recordings in several common audio formats.
Before recording, configure the program to capture system audio instead of the microphone. On Windows, select Windows WASAPI with the Loopback input, while macOS requires a virtual audio driver such as BlackHole or Soundflower.
Since everything is recorded in real time, the recording process takes as long as the music itself, and metadata like album artwork or artist information is not retained automatically. Even so, it is still a straightforward way to convert Apple Music to MP3 using an offline workflow.
If you just need MP3s for an older car stereo, you could record the audio manually with Audacity/OBS, but that’s pretty time-consuming for a whole playlist. A dedicated tool like Sidify is probably the easier route if you have a lot of songs to convert, since it can output MP3 and keep the track info.
