so, i just got my tablet pc (looks pretty decent btw), so the guy instaled windows 7 on it, it originaly came with xp tablet
so i go into comp proporties and i'm greeted with this:
so i see that 7 hasn't been activated (yes, there is a key under that black bar) also the xp tablet code on the bottom of the pc is still intact/ readable
important note: the programs i need to run MAY only run on xp/32-bit (the people who made the spec sheet at my school most likely aren't the brightest)
so my question is: can i leave this unactivated (do i need to NOT connect to the internet?) save the key (for a near-future build) torrent win 7 and xp tablet, use the key on the bottom of the computer for xp, use the key shown (you know what i mean) on the future build, and save $100
i don't want to pirate, and if i could spend/ save $100 it would really help alot
