Guys its my first PC build I would really like HELP!
- Budget. How much are you willing to spend?
$800 - Where do you live (what country), and what currency do you use?
United States - -Is there a retailer you prefer?
NewEgg but would be best but im looking for better prices.. - Do you need or already have peripherals? (this can add to costs)
Have a wireless keyboard and mouse for now - What will you be using your future computer for? Gaming? Rendering? Mix of both? Or is this a home media PC?
Ill be using it mostly for gaming and would like to record my game play - Do you overclock or want to get into overclocking?
Would like to overclock down the road - Do you plan on going for custom watercooling now, or in the future?
Would use anything just to have a cooler pc since i would like to have graphic settings at high - OS. Do you need a new one?
yes, prefer windows 8 64bit
If you Game-
- What kind of settings do you like or what FPS do you want to play at?
Settings would be either Ultra, High, little less than high and The higher FPS the better. Im new to PC gaming so i wouldnt know what is a good FPS to be working with. - What resolution will you be playing at? //or would like to play at.
I would be playing at 1080p for now on my TV - What kind of games do you like to play?
MMORPG's, FPS, Strategy - What specific game will you be playing (if applicable)
BF4, Titanfall, Planetside 2, WOW, Diablo 3, Destiny
