I got a few case fans that I desperately need to install. I need positive air flow, but my motherboard(Asus M5A78L-M) only has 1 fan header. So there there a cheap fan header that's 1. Reliable and 2. Under 7 dollars? I have 2 case fans but i could use just one.
Well there are these which let you plug into a 4 pin molex,
and there are these to control the speed.
You may find a fan controller on sale for your budget like this
hey, look for those on ebay
there is a sata power version http://www.frozencpu.com/products/20988/ele-1196/Swiftech_8-Way_PWM_Cable_Splitter_-_SATA_Power_8W-PWM-SPL-ST.html
2 fan on 1 molex
http://www.aquatuning.us/air-cooling/controllers/?p=3
For when you go the cheap way beyond that you get to fan controllers in 5,25" bays
Yeah you can get fairly cheap fan controllers that work fairly well ... I'd give that a shot.
I have a couple different fan splitter (Noctua, Phobya and a "no-name" brand). They differ in type and number of connectors. The Phobya one I would not recommend (expensive and after only 3 weeks 2 of the wires came loose, I would be able to fix it but I'm too lazy).
The one from Noctua you just plug into the MB.
The Phoby is also a cable-extender (in case you want to connect from different locations, not just for example 2 front intake fans).
The last one connects directly to the PSU via molex. Got a bunch of them fairly cheap (under 10€).
I can only say for sure that the one from Noctua supports 4pin PWM, not sure about the other ones (the last one definitely not).
Edit: If you don't care about regulating the fan speeds and just want to let them spin at a constant rpm, I would recommend this one -> http://www.amazon.com/Zalman-ZM-MC1-Multi-connector-Add-Fan/dp/B000FAKUE6/ref=pd_sim_147_3?ie=UTF8&refRID=1FVJ453GJCFQ7W8F9WK2 Matches the last pic in my post.
