Need help with old QIC-80 / DC2120 Tapes
I found some old QIC-80 tapes in storage, 250MB. I don’t have any old motherboards with floppy controllers (the original drives came with a splitter for the floppy cable) and there were no SCSI drives made to handle these tapes, so I decided to go with the parallel port solution. I found on eBay.
I had to look up some old Linux docks on the ancient paride driver:
http://cyberelk.net/tim/parport/paride.html
The liquorix kernel still has all these modules, so I went with Debian Bullseye + liquorix. I used a PCI-E parallel port card which shows up in the kernel logs as the following:
[   14.965405] parport_serial 0000:01:00.0: enabling device (0000 -> 0003)
[   14.965539] parport0: PC-style at 0xf100, irq 97 [PCSPP,TRISTATE]
[   15.053879] ppdev: user-space parallel port driver
I can modprobe the individual paride protocols and register them by number:
[  167.745144] paride: epat registered as protocol 0
[  362.606370] paride: bpck registered as protocol 1
Unfortunately, none of them seem to work. For example, if I run modprobe pt drive0=0xf100,1, it takes a while to probe and returns that it can’t find any devices.
[  369.920354] pt: pt version 1.04, major 96
[  369.924266] pt0: Sharing parport0 at 0xf100
[  370.225661] pt0: bpck 1.02, backpack          unit 0
[  370.225663]  at 0xf100, mode 1 (8-bit), delay 4
[  376.508496] pt: No ATAPI tape drive detected
I tried all the protocols with the pt driver and several with the pg driver. Most attempts return immediately saying the device cannot be found. Only the bpck driver seems to take any time to actually probe the parallel port. The device is on (it has a pretty loud fan).
I took off the cover and have these photos, but it’s difficult to get under all the cabling and see the actual IDE->parallel port chip. I can’t seem to find any data sheets on this device either. It didn’t come with the original floppy disk (not that I even have a floppy drive) and the specs in the manual just mention temperatures and tolerances, not actual chipsets.
Not sure what to try next.
oh what the hell … of course this isn’t going to work! This is a floppy drive based tape reader! It’s not going to work with a Parallel Port IDE driver! Looks like there was a floppy tape drive in the earlier Linux kernels called ftape. It’s been removed for years, but I should be able to use it if I go back to Debian 3 / Sarge:
