Need help with number keys!
So, to start off I bought the Razer Blackwidow Tournament Edition which doesn't have a keypad. I have been using trainers in most games now and it is almost impossible to use them without a keypad. Is it possible to use a registry hack that would turn the regular number keys into keypad keys if you press caps lock?
http://www.amazon.com/ADESSO-AKP-220B-Adesso-Mechanical-Numeric/dp/B0038KN3YY/ref=sr_1_8?s=electronics&ie=UTF8&qid=1375288264&sr=1-8&keywords=numpad
I recommend instead of trainers, using CheatEngine. In cases of money/resources you'll be able to easily find and adjust values yourself, in cases of things values of which you can't see, you'll have to download tables from official forum. So far I haven't seen many games for which there are no CE tables.
+1 on CheatEngine, its very nice, but if you constantly find yourself annyoed by the lack of a numpad I recommend just buying a cheap usb numpad. The link provided by brennanriddell is a good quality one, but if you dont use the numpad that much you can prolly get away with using a budget one.
https://dx.com/p/silicone-usb-18-key-numeric-keypad-numpad-for-laptop-black-27613
6$ with free shipping to just about anywhere.
Oh, and if you only need the numpad for the trainer you can use the onscreen keyboard in windows.Control Panel » Ease of Access Center » On Screen Keyboard.
