Need help with gigabyte MZ23-suo and qs turin
I have a Gigabyte Mz23-suo motherboard and an Epyc Turin 64 core QS chip. I’m trying to build a home server but can’t seem to get it to boot. I can get into the BMC. I had an ipmi alert that showed a cpu then 5 minutes later it said there was no cpu.
1300watt power supply brand new
only 16 GB of kingston Ram until I decide to sell half my liver and a kidney
gigabyte Mz23-suo brand new
supposedly “new” Turin 100-000001247-12 QS
Rosewell rack 4u case
appreciate any help
motherboard is rev 3 with r03_f02 bios
Wont post with or without Rdimm
power supply works in another system
Remove the power connectors from the motherboard, inspect the motherboard headers & cable ends, plug them in and be sure they are fully inserted, make sure you have the 24 pin, the 6 pin 12v PCIE, and the 2x 12v CPU connectors all hooked up.
The manual said “If the 12V power connector is not connected, the computer will not start.“ and I can see a connector not being inserted all the way, or making poor contact, or wiggling loose during assembly/ testing.
Make sure you have a single stick RAM setup with it in the A0 slot.
Worth double checking CPU mounting torque & the cooler mounting torque. I’m assuming you double checked there weren’t any oddly positioned motherboard standoff left in the case where there is no hole on the motherboard, because a dead short to the case would cause all sorts of issues.
Hello and thanks for the reply,
I have reinstalled the cpu a couple of times and torqued everything
all power connectors are plugged in a few times from removing the board from the chassis
I currently only have one stick of RAM and have double checked the slot is A0
I double checked the standoffs and it does the same thing out of the chassis
I might try to contact Gigabyte to make sure the bios supports the processor, all the research I did before buying it said it would work though
Probably a good idea, they had an odd blurb on the board’s website that says “AMD EPYC™ 9005 server processors require OEM enablement and a BIOS update from your server or motherboard manufacturer if used with a motherboard designed for the SP5 socketed AMD EPYC™ 9004 server processors. Contact your system manufacturer prior to purchase to determine compatibility.”
But I wasn’t seeing that in the motherboard manual which is kinda odd, especially because the manual implies it should just work with a 9005 CPU.
Though checking the motherboard QVL list I don’t see a “1247” CPU so maybe it’s just an incompatible CPU
Thank you for sending the photo and confirming that the processor is a 9535 QS (Qualification Sample).
Unfortunately, because this is a pre-production sample processor and its specific OPN is not published in AMD’s public documentation, Gigabyte does not have a way to verify compatibility or provide BIOS support guidance for this CPU. The MZ23-SU0 validation and support matrix only covers production processors listed on our QVL.
As a next step, we recommend testing the CPU in a different compatible SP5 motherboard, if available, to determine whether the processor itself is functional. If the CPU is not recognized on another platform as well, that would help indicate whether the issue is related to the processor rather than the motherboard.
If you have access to a validated production EPYC processor, you may also test the MZ23-SU0 with that CPU to confirm normal motherboard operation.
Best regards,
Paython Veazie
Field Application Engineer
GigaComputing
Sounds like it’s either a dead/ failing CPU or it is simply incompatible with that motherboard, should probably return it if you have a return window still.
