Need help with a noisy new liquid cooler!
Yesterday I overhauled my system and installed the Glacer 240L AIO Cooler in my rig. I'm getting great temps but I have a few questions regarding the fans. I plugged the two fans attached to the radiator into two open CHA_FAN headers. As a result the fans run pretty fast and are noisier than my old Air Cooler. The other thing I notice is that when the CPU performs almost any task (like opening my browser) the fans quickly rev up up to what appears to be max speed and then back down.
Do I need to plug the fans into the CPU_FAN header instead to fix this? I have one CPU_FAN Header and one CPU_OPT Header but the CPU_FAN Header is currently occupied by the cooling block's dummy connector. Can a radiator fan take its place and then I can just plug the other into the CPU_OPT header?
Any input would be greatly appreciated as I don't feel comfortable using my computer yet with the fans running so fast and loud
x2 of these --> http://www.amazon.co.uk/NF-P12-PWM-120mm-Cooling-Fan/dp/B006I6HMXI/ref=pd_sim_sbs_computers_2
Or a fan controller
So it has nothing to do with connecting the radiator fans to the chassis fan headers and not the cpu fan headers? Are there any fan settings in the BIOS I need to alter?
Stock fans on AIO coolers are loud thay are bogstandard high performance sp fans thay spin at a much higher rpm (upto 3500rpm) even at lower rpm's thay can be louder than your case fans.
CM lables that cooler to be 40.33 dBA (thats unacceptable tbh)
Awesome. Thanks for the input, guys! I may pick up an NZXT Sentry Mix 2 Fan Controller this weekend.
I had the same issue as you!!! Connect the fans to the CPU fan headers and the noise will magically disappear.
