Need help troubleshooting Citrix workspace
Hi,
A bit of a longshot but i’ve been trying to replace Windows with Linux for a while now and i’ve managed mostly good but now i am stuck. For work we need to use Citrix Workspace to remote into a virtual desktop. In windows this works flawlessly but with Linux and more specifically Pop_Os!, i get this error:
Screenshot from 2020-12-02 16-54-08
How can i add this CA to my trust store? I’ve tried to download the certificate manually from godaddy and the importing it via the ‘update-ca-certificates’ command but it still complains about the certificate so i’ve probably screwed something up somewhere.
Any help or guidance would be appreciated, thanks!
Get cert from GD and add to cert store?
https://certs.godaddy.com/repository/
Also certs are usually distributed with os updates.
Are you running this in Wine or Proton?
Hi, thanks for your reply.
I have done this step, i’ve downloaded “GoDaddy Class 2 Certification Authority Root Certificate - G2” and imported it to my root store by placing the certificate in ‘/usr/local/share/ca-certificates’ and then running ‘sudo update-ca-certificates’. I still get the error message though.
Neither i think. Citrix Workspace has a native linux app that i downloaded.
https://www.citrix.com/sv-se/downloads/workspace-app/linux/
I actually found the solution to my SSL problem here: https://en.code-bude.net/2017/05/03/how-to-fix-ssl-error-61-in-citrix-web-receiver-on-linux/
Now i dont get the SSL error anymore. But for some reason the virtual desktop never stops loading.
Run it in a terminal and look at the console output.
