As the title says I need help to find a small desk or stand for my TV I use for work. So, what I basically like to do is moving around a lot and I spend 1/3 of the time on my sofa, 1/3 standing and 1/3 at my desk. I like prefer to switch my posture during the day because it seems like if generally feel better when doing this ![]()
Anyway, I got my desk covered and since I usually stand during calls the screen of my notebook suffices. The last thing that remains is my sitting on the sofa which has the following setup:
There are two matressess on the the sofa so I am sitting at around 55cm/21.65in. I also have a small ladder which reaches 63cm/24.8in where I put my 4k 43" TV on top. This works acceptable but I would actually prefer the TV to be a bit a higher and maybe even closer. Unfortunately, the bottom of the ladder touches the bottom of the sofa and therefore I am out of luck. (The TV also has the usual Samsung V shaped large stand.)
Anyway, now I am looking for either a small desk and small mount I can use instead or a larger stand I can pull close enough. Another reason the current solution is a bit annoying is because standing up is a bit of a hassle.
So, any ideas or any feedback is welcome! Thanks!
