Need help to decide which monitor to buy!
Good day guys, need some advise on which monitor to buy.
1st choice Asus VG278H,
2nd choice Samsung S27A950D.
Please, write down which 1, u guys perfer and why you chose it.
Thank You.
asus is a good quality brand, but so is samsung
get whichever has lowest response time, or if that's the same, get the cheaper one
Spec wise, nearly the same. Samsung Panels are generally pretty high quality. Pick the lower price.
