Need Help Over Clocking my HD 7950!
Hey, i recently built a custom pc and have already overclocked my cpu and i am currently trying to oc my gpu but am having some difficulties doing so. i tried using the AMD catalyst because it looked easy, but i dont think i have it. but anyways. Here is my build .
ASRock z77 extreme 4
Intel i5-1200k OC 4.5ghz
8b g skill sniper series ram
Gigabyte Radeon HD 7950 STOCK
and i was wondering if someone could please link me to a video or link me to some programs and help me overclock this darn graphics card!
Thank you! I realy need help. i am beginner at Overclocking Gpu.
Ive already looked up some videos and downloaded some Oc programs, but i havent had ay luck.
Please Help me! Thank You All!
MSI After Burner or Sapphire Trixx are good utilities
Check "Ati Tray Tools"
But the Catalyst is the best choice when it comes to auto-overclocking..
In my experience, you could get the gpu clock to run stable bu 10% and the memory clock up to 20-30 %
BUT I don't recommend clocking the GPU and the MEMORY clocks at the same time !.... If you Clock the GPU, you should set the MEM clock some steps back in order to gain performance and stay stable. I personally prefer overclocking the MEMORY clock, because it's more clockable, and the games load faster.
Note that if your settings in bios for overclocking the PCI are set to Default/Auto .. you are overclocking the gpu by overclocking the motherboard ! So it may seem running at stock speeds but it's actually not... and you can't over-clock it even more without getting problems.
pp. My configuration is OLD compared to yours but the basics are the same so good luck :)
I have that exact card at 1050/1450 @ 1.08V Stable using MSI afterburner, Afterburner is honestly the best for overclocking by far IMO
