Here is my build http://pcpartpicker.com/p/1E6S6
To start off I installed all the hardware properly. When i do the first test to see if everything works my cpu fan spins for maybe 2 seconds and stops then nothing happens when i hit the power button again until i unplug the psu and plug it back in. So i wondered what caused this then i ended up removing piece by piece to see what the issue was. Finally, I removed my GPU from the PSU and the pci slot then my system worked. The light in front of the case was on, the fans were spinning on the cpu and the psu.
So my question is. Do i have to replace my 430W psu or replace my GFX card?
P.S I had no monitor or peripherals connected at this point.
