I am wondering if there is a fix for, this blue screen error or do I need to remake the vm. If you need an xml file tell me.
I’ve seen that bsod with too agressieve aspm settings, maybe try disabling it in windows and or the bios on the host or vm.
When is the bluescreen occurring?
That said, try disabling aspm in the bios.
Not sure what your exact setup is but I was getting blue screens on boot up until I added the following to my grub config:
*I basically added “kvm.ignore_msrs=1” to my grub parameters and got it to work.
https://patchwork.kernel.org/patch/42605/
