System sensors do not come up in vmware aswell as storage censors and for system sensors it says this: "This system has no IPMI capabilities, you may need to install a driver to enable sensor data to be retrieved. "
For storage: The Small Footprint CIM Broker Daemon (SFCBD) is running, but no data has been reported. You may need to install a CIM provider for your storage adapter.
Here is the hardware:
cpu: ryzen 7 3800x
gpu: 960( just an old one i had laying around needed it to get it to boot)
motherboard: msi b450m pro-vdh max
storage: - 500gb crucial p1
- 2x 500gb samsung sata ssd
I looked to see if there are any drivers and I couldnt find any. I had to make a custom vmware image to get the ssd and network to work.
