RTX 3060 12G GDDR6 INNO3d | R5 5600 | B550 Gigabyte V2 | Deepcool AK400 |MSI a650bn PSU | 32 GB DDR4 3200mhz corsair vengeance | Corsair 512 SSD NVMe M.2 Gen 4 | Galax Rev 1 | 1200 $ Budget the reason im not going for an amd gpu is coz i play fortnite mainly and fortnite isnt optimized for amd soo yeah do i have any bottleneck issues or any better hardware upgrade (except GPU ) please and thank you
OK, lemme get this right: you play Fortnite, which heavily favours Intel CPU’s. Yet you have an AMD CPU in your list. Or is that what you now have and you want something Intel-based?
Also, please use punctuation, it’s designed to make written sentences better readable and thus more understandable.
I would change the PSU to something like FSP Group, Seasonic or bequiet!, but the rest is alright. I’d say that 512GB ain’t going to be enough for a modern PC, unless you have a NAS (I can live with 256GB storage only because of my large NAS, but not sure what you have). You might want to get a 2 or 4TB SSD in addition to that corsair one (I prefer micron / crucial and adata ssds over corsair).
Modern games take 100GB+ often times now, and since you really shouldn’t fill TLC based SSDs more than 50-60%, you will not have much space for anything on that drive. Id grab a 1TB minimum
What country are you shopping in, I only see that case in Indonesia
Inno3d is definitely Asian market. Indonesia sounds about right.
Its a game. Not optimized does not mean you will not get good KDA and optimized hardware wont mean you wont die to the enemy. At the end of the day, its a tool.
Also as @Dutch_Master says, kindly do your due diligence and construct your thoughts into something more coherent as a courtesy to the members of the community. Otherwise they wont be inclined to reply.
I am asian too, btw. Your SEA neighbor.
Ok, so let’s clear this up, this is what you want to build right? Since you’re talking $1200, I’m thinking your budget is way off unless it’s AUD. So, AUD PCPP to the rescue, I assume this is what you want to build. I could not get a quote on the case though:
Type | Item | Price |
CPU | AMD Ryzen 5 5600 | $194.77 |
CPU Cooler | Deepcool AK400 | $39.00 |
Motherboard | Gigabyte B550 GAMING X V2 | $219.44 |
Memory | Corsair Vengeance LPX 2x16 GB DDR4-3200 CL16 | $99.00 |
Storage | Corsair MP600 GS 500 GB M.2-2280 PCIe 4.0 | $69.00 |
Video Card | Inno3D Twin X2 GeForce RTX 3060 | $469.00 |
Case | GALAX REV-01 | - |
Power Supply | MSI MAG A650BN 650W 80+ Bronze | $79.00 |
Total | $1169.21 |
If this is the case, here is what I would do. Not much budget to work with, but if you can stretch budget with $70 AUD, these parts may work better:
CPU | AMD Ryzen 7 5700X | $269.00 |
CPU Cooler | ARCTIC Freezer 7 X CO | $35.00 |
Motherboard | MSI B550M PRO-VDH WIFI | $175.00 |
Memory | TEAMGROUP T-Force Vulcan Z 2x16 GB DDR4-3200 CL16 | $94.00 |
Storage | TEAMGROUP MP44L 500 GB M.2-2280 PCIe 4.0 | $69.00 |
Case | Antec NX500M ARGB | $69.00 |
Power Supply | Thermaltake Toughpower GX1 600W 80+ Gold | $86.60 |
Total | $1266.60 |
Now you have an 8 core setup. You also have an equivalent cooler, RAM and drive but saves you $10-$20. The MSI board is really good for the price. The case is the cheapest I could find with a mesh panel and fans, but if you can get the Galax Rev-01 for similar money it is most probably a better buy. Finally, power supply is now gold. Unfortunately semi modular cost $30 more, and we have already exceeded budget, so yeah…
