I decided to listen to Logans advice of getting the 880s. And that's all fine, but ofcourse I need an amp for the headphones. In my country I don't have many options, mostly USB DAC/amp combos. And I've heard that USB powered accessories don't have enough power to power my 250ohm headphones.
Aside from that, I have a limited palette to work with, so refrain from posting amazon/newegg links because those are havens I have not yet reached (I'm not from the US, obviously). Though I will link you amazon links just so you can see what I can buy here ( for roughly 50% more expensive price though )
Some choices that I dug up after hours of research:
http://www.amazon.com/gp/product/B00LP3AMC2/
It's well within my budget, only about 120$ here, and I have around 180$ to spend.
http://www.amazon.com/E12-Blanc-Portable-Headphone-Amplifier/dp/B00B6QXWIY
If this one is any better than the first one, I can go as far as cashing out for it. It's 180$.
This whole world is confusing for a mere peasant such as I.Any help is greatly appreciated, thank you!
