Need help. "Error Opening Block Database"
Hello I started my computer up today and opened bitcoin to find the message: "Error opening block database. Do you want to rebuild the block database now?" I went through the log file and found this:
Bitcoin version v0.8.5-beta (2013-09-12 13:35:18 +1000)
Using OpenSSL version OpenSSL 1.0.1c 10 May 2012
Startup time: 2013-12-07 22:03:05
Default data directory C:\Users\Warren Flick\AppData\Roaming\Bitcoin
Using data directory C:\Users\Warren Flick\AppData\Roaming\Bitcoin
Using at most 125 connections (2048 file descriptors available)
Using 8 threads for script verification
init message: Verifying wallet...
dbenv.open LogDir=C:\Users\Warren Flick\AppData\Roaming\Bitcoin\database ErrorFile=C:\Users\Warren Flick\AppData\Roaming\Bitcoin\db.log
Bound to [::]:8333
Bound to 0.0.0.0:8333
init message: Loading block index...
Opening LevelDB in C:\Users\Warren Flick\AppData\Roaming\Bitcoin\blocks\index
Opened LevelDB successfully
Opening LevelDB in C:\Users\Warren Flick\AppData\Roaming\Bitcoin\chainstate
LoadBlockIndexDB(): last block file = 91
LoadBlockIndexDB(): last block file info: CBlockFileInfo(blocks=299, size=65504445, heights=268263...268561, time=2013-11-06...2013-11-08)
LoadBlockIndexDB(): transaction index disabled
LoadBlockIndexDB(): hashBestChain=000000000000000239e967c1e1f03a75b94ccc34724bc8258fb6d7dcd8aa355b height=268524 date=2013-11-08 11:07:10
init message: Verifying blocks...
Verifying last 288 blocks at level 3
LevelDB read failure: Invalid argument: not an sstable (bad magic number)
Flush(false)
DBFlush(false) ended 0ms
StopNode()
Flushed 0 addresses to peers.dat 31ms
Committing 144 changed transactions to coin database...
Flush(true)
DBFlush(true) ended 0ms
Anybody know a solution?
