Hi I'm about to build my first pc and thanks to the Teksyndicate forums help as well as hours of research I've picked out this build: http://pcpartpicker.com/user/jas903/saved/3I78
I've been reading tons of reviews on the Noctua NH-L9i 57.5 CFM CPU Cooler and they all have said that it can block higher-profile ram. How do I know if what I have will be blocked before I buy the product?
I HIGHLY doubt it that CPU Cooler will block any RAM on the motherboard because its incredibly small. depends how insanely big the ram is. which is only common on high clocked Ram like stuff above 1600mhz which you probably wouldn't need for gaming or benefit unless you are using integrated graphics anyways. i Personally have that CPU cooler its Bloody Awesome for the size and price. and can keep a tiny overclock cool. Mine being 4.2ghz and never passing more than 80C. more in the 75-78C in a gaming load. also on the spec sheet and on the noctua website it says that CPU cooler has 100% Ram compatiability. so you should be fine.
