Need help choosing a AM3+ board
Hello, I'm planing a update of my system(current specs in my profile), mainly because at the moment the CPU is bottlenecking in games(GPU usage in some games go up to around 30% while cpu is at 100%) and because I want Sata Rev. 3 for SSD.
I've chosen a CPU and a SSD already(AMD FX-6350 and 840 pro), and now I am stuck between 2 boards.
Board 1:
http://www.asus.com/Motherboards/M5A97_LE_R20/#overview
It's 5 €'s cheaper(doesen't really matter), but it's Asus, and has great software, to me it seems that it has better power phase.
Board 2:
http://www.asrock.com/mb/AMD/970%20Extreme3%20R2.0/
It's black, all that I can say.
There are other options too, but not sure which I should get, I plan overclocking a bit, but nothing major.
Ofcourse wisest option would be a 990FX board, but I'm just not sure that I would profit from it much.
non le version of the asus board
The Non-LE version has the same problem as the LE version, only 3 case fan headers.
