Need feedback on my build so far
http://pcpartpicker.com/p/2zDYq
my little brother wants me to build him a pc but doesnt want to spend to muc this is what i got so far. his budget is 650$ and i just want to know if i'm getting good bag for buck
thanks in advanced
-kevin
http://pcpartpicker.com/p/2zH3y
$700 build that's A LOT better... I hate working an OS into budget builds :P
http://pcpartpicker.com/p/2zHbZ
http://pcpartpicker.com/p/2zHgj with os
it should be noted.. the R9 270 "ships within 2-5 weeks" ... just saying... you're a beast at getting things into budgets BTW... I can't bring myself to recommend anything less than the FX 6300... it's not in my genes :P
Does the phenom perform ok?
Danke. Phenom 965 is competitive with the FX6300 at stock, but the FX6300 is much more overclockable. Unless you meant the Athlon? lol
Bench:
https://www.youtube.com/watch?v=qIT9uLDjZcg
I'm sure there will be other 270s available, which are simply underclocked 270x cards. And why are OS prices ridiculous in the US?
I couldn't tell you... I mean I'm pirating windows for a work build if that tells you anything :P
Bench shows the performance of the 750k
+1
The X4 760K is a mighty fine CPU for the price.
