Need an upgrade: budget $250
Hi, I live in the midwest. I'm looking to increase FPS and bandwidth on my PC. I play dota 2, BF3, Skyrim, dirt 3 and flash games. I stream sometimes to other PCs and also do photoshop and media editting. My budget is 250 dollars. I think I need to update my graphics card & case, but what do you guys think. 280x is a bit overpriced atm (299 intial price) now 380-460 dollars so I think, I'll wait 4-6 more months to upgrade. As noted on title, my budget is 250 USD.
Here's my specs:
CPU: AMD FX 8350
Motherboard: Asus M5A99X Evo r2.0
RAM: Adata 1866 (4x2gb) + Kingston 1866 (4x2gb) both running 9-9-9-24 (2T) @ 1.65v
OS HD: Sandisk Ultra 256gb
OS: windows 8 64-bit
HD: 4(2TB) seagate 5900rpm
Case: Antec 900 (thinking Corsair 750)
PSU: OCZ ZX series 1250w
DVD: Liteon 4x BDR
Keyboard: Gigabyte K-6800
Mouse: Logitech G500
Backup mouse: Razor Deathadder
Monitor: 3X LGs 21.5 montiors either in portrait 3240x1920 or landscape single display (2 off)
... where is your gpu??? and wait till prices go down on the r9 280x, then get it.
Yeah, what's your GPU? xD
I would suggest upgrading with a $250 GPU like a GTX 760... so, you know, you can see your monitor post... it will definitely improve FPS from black monitor to playable :)
