Alright, well this is my first time so i will try my best. I would like to know what anyone thinks about my current setup and maybe a few helpful tips onto which i can inprove on. Greatly appreciated!!
AMD Athlon 64 x2 4450e
running windows 8 x64
3Gb of DDR2 ram nothing too expensive
Nvidia Quadro FX 3450/4000 SDI
1 2Tb Hitachi Hard drive and a 200GB HDD
Creative SB X-Fi 7.1 sound card
i will soon get an EVGA GeForce gtx 460 but i will swap it out with another GPU in a very near future
I am going to guess you are getting the gtx 460 used but if you could get a quad core cpu and 4-8gb of ddr3 ram you would have a proper gaming machine. some cpus you could look at are the phenom ii x4's, FX 4300/6300/8350 and athlon x4 750k. also the intel i5 3570k/4670k if you have a bit more money. depends what you want to do and how much money you have to spend
well i got this setup as a last minute resort because my motherboard fried for some odd reason and a friend hooked up the parts. I have been slowly building it up and have been thinking about the phenom ii x4. Everything works fine. I've been using this setup for producing music and occasionally playing games
