My apologies if this doesn’t make sense. I kept adding to the post and really need to get it out there as I’m only off work for this week and going back to work will be busy. Happy to re-write if this isn’t technical enough/doesn’t make sense. Sorry in advance and happy to take that feedback on board and review.
TL;DR
Hardware - Can I use Ryzen 9 to play around with home server and gaming PC at the same time?
ITJobs - Looking to transition from CS teacher to IT Job. What server projects can I do to prove skills so I don’t have to start from scratch, or is that unrealistic to not start from sub £30K without direct industry experience? Happy to pick up certs if helpful.
I am looking to build a new system as mine is very old. I’m happy to spend decent money on it but I am wondering whether consumer hardware could be helpful for home lab.
Background
I’m a CS teacher with a CS degree. I’m possibly looking to pivot away from teaching into tech. I don’t have a background in IT (work wise) and can’t really afford to start from position 0 in terms of salary.
So, I’m looking to play around with some home lab stuff as proof of my technical expertise…that I will need to learn.
Long Term Plans
I know I would like to have a CCTV system (I don’t trust packages but there is a desire to have a video doorbell) and the most obvious being storage server.
Beyond that, I need to practice industry skills, so will likely look into things client Pis.
Main Consideration For the Build
One PCTo Rule Them All
I’m thinking about going with the AMD Ryzen 9 9950X 4.3 GHz 16-Core Processor.
My logic is that I may be able to slice some of the CPU off for home lab stuff whilst still having this as my main rig for gaming. I thought I would get the integrated GPU version due to not having pass through for VMs on a GPU, so hoping it would be more useful as a 3rd GPU which would take up space in the PCI slots. - As it would just be an ATX board, not much room for expansion.
In terms of the homelab not taking off; I can use the GPU version failsafe if the graphics card fails me. I would also be using the Ryzen 9 as I like to use VMs for work/admin stuff, so could still benefit from multiple cores.
I know there could be issues with no ECC support but as a silly little homelab that can turn into something serious if it is successful. I’m also aware that 16-core isn’t going to be massive as, essentially, half the CPU will power 1 computer. Not sure how many cores I’d need and be happy to dual boot (as they are just play projects) if that would still work.
Two machines
The other option is a cheaper CPU/Motherboard and buy a dedicated server. The issue is, I don’t have too much space in my room for a workstation + PC, let alone a server blade. However, I could definitely get a miniPC.
The other main issue is the noise, as I sleep in the same room as my office. - Not ideal but it is the space I have.
I do live below an attic, where (in the very long term) I would put a server blade if the homelab was a success. But this is an if more than a will. - Mostly as I’d hope to wire the house; either when we have the electrical cables done or using the existing analogue
Questions:
-Would 64GB be enough for a home lab + Gaming machine simultaneously? (At least for a storage server + practice)
-Would having two separate hard drives, one with TrueNAS and another with my gaming OS, allow me to use the full PC when the server is powered off?
-Do you think I’d be better off getting a Ryzen 5/7 for gaming and buying an old server?
-Will the lack of ECC memory be a major issue, considering it is mostly a sandbox to play in?
+Bonus if anyone can give some advice of what to do/certification that may help for a job in IT, server-side/support jobs. - It has been suggested to do Google/AWS cloud certs to replace experience.
Happy to provide more info if possible.
EXTRAS
My Prospective Build and Rationale
I haven’t given too much thought to the motherboard and struggling to find a storage heavy chassis as I live in the UK and second-hand market is likely to be, whatever is available. I’d likely look at repair shops.
I’m thinking of getting the GPU version due to not having pass through for VMs on a GPU, so hoping it would be more useful as a 3rd GPU. It can also act as a failsafe if the graphics card(s) fail me.
Asus ProArt X870E-CREATOR WIFI ATX AM5 Motherboard
For the 2 x PCI 5 and 1 x PCI 4 slots which I aim to connect a thunderbolt adapter to, like Linus did in his personal build (https://www.youtube.com/watch?v=TgRXE9mUHJc) along with the helpful number of USB ports and dual ethernet. Will be looking at alternatives though, it is just what jumped out as compatible with ASUS’ add-in card but recently saw issues with the other model.
Crucial Pro 64 GB (2 x 32 GB) DDR5-5600 CL46 Memory
Start with 64 but happy to upgrade later if this is needed.
3070Ti Founders Edition
I already have the GPU.
