Need Advice: Level1Techs 8K KVM – HDMI vs DisplayPort for Dual Ultrawide Setup
KVM Model:
HDMI 2.1 KVM w/EDID & Serial Control - Dual Monitor - Four Computer
10-gigbit
Problem:
I’m looking to pick up a Level1Techs 8K KVM (4-port, dual-monitor), but I haven’t had luck getting a reply through the question form on the site so I posted on Reddit and they suggested I post here for Amber and Wendell. See below. Any help is greatly appreciated.
Other Notes:
Hey all,
I’m stuck deciding between the HDMI and DisplayPort versions. The main deciding factor for me is EDID support — I really want consistent display detection when switching inputs, which (from what I gather) is included on the HDMI unit but not on the DP version. I’d prefer not to rely on any software-based EDID workarounds.
Here’s my current and upcoming setup:
Monitors (stacked):
  • Samsung Odyssey Neo G9 (57") — DP & HDMI available
  • Samsung Odyssey G9NC (49") — DP & HDMI available
Systems:
  • Laptop 1: HP ZBook Z Fury – dual USB-C outputs (connected through HP Thunderbolt dock)
  • Laptop 2: Alienware gaming laptop – HDMI and Mini DP outputs
  • Desktop 1: Older custom build – dual DisplayPort outputs (used occasionally)
  • Desktop 2: Custom build (planned) – will be fully DisplayPort-based
I’m expecting to use some adapters in-line no matter what, but I’d really appreciate input on which KVM version might work best with this mix.
If anyone has first-hand experience with the 8K HDMI vs DP KVMs, or has dealt with similar multi-system / multi-monitor setups, I’d love to hear your thoughts before I commit.
Thanks in advance — and huge shoutout to the Level1Techs team for building such great hardware! :raising_hands:
The general inquiries are currently backed up from the 20th since we prioritize technical support tickets. So if that is you I will be replying to those today and trying to empty the queue :+1:
If it’s older then the 20th maybe there was a typo in the email? Feel free to DM me the email you used and I’ll see what happened.
Thanks for the reply Amber, really appreciate it. Yes, it’s from the 20th or so. No worries, take your time. Just finally found a KVM solution that seems like it will WORK and wanted to make sure I’m getting the right product. Thanks again.
Yup I actually just replied to you. Haha
