Looking for a new monitor for gaming. Needs to be pretty decent. And at least 23" But no bigger than 30". Any suggestions? No 1440p Unless you think it is a viable option with the New series AMD Radeon HD cards.
Thanks
Thanks
I would highly suggest choosing 1440P for that size. 9000 series should handle it no problem.
I would say this is probably the best monitor otherwise the benq xl2420t is nice too if you want fast response times for more competitive gaming. Otherwise look at the X Star 27in if you want better picture quality.
thanks i will look into these
