http://pcpartpicker.com/user/Fink/saved/2Ivx
It says that to uses 422w but the power supply is a 450w.
But the max power useage of the 780 is 400w so I am confused if the psu is enough.
More often than not graphics card makers overstate the needed power for the card. try to go with a 500W psu just to give you some overhead in the future.
for a single gpu setup i would say pickup a 650W psu, then you have allways enough headroom. XFX, seasonic, Corsair etc
Ah, you're lucky because the case you're looking at can actually contain full size atx power supplies with minimal effort. Check out the amazon review and user pictures! But you might have to give up an optical drive, in the rare case you actually need to use an optical drive there are decent usb 3.0 ones now. http://www.amazon.com/Silverstone-Tek-Aluminum-Computer-FT03B-MINI/product-reviews/B0085S33XK/ref=dp_top_cm_cr_acr_txt?ie=UTF8&showViewpoints=1
yeah the psu formfactor could indeed be an issue, sfx psu´s are hard to find ☺
