Alright so I have some general questions about upgrading I was hoping someone could answer. Here are my specs http://uk.pcpartpicker.com/user/Matthew12106/saved/d86p99
Just a little backstory, as you can see I'm currently rockin a Msi r7950 Boost OC. It's a good performer but the temps and the noise.... ehhh
So I was planning on getting a r9 r290 but I held of because of the 900 series plus although my 550w would be ok for a r9 290 I just wanted more headroom maybe for OCing my Cpu. I'm so happy I did as the 970 seems like an amazing value card! cool and quiet just want I want
Question 1: What do you have to do on the software side of upgrading your gpu. So I'm using AMD so I know I can't just swap the cards out and everything will work. I think, but I'm not sure when I downloaded the 14.4 amd drivers it told me and showed my how to install Catalyst control center and the drivers and stuff here is the link . So is that everything I have to do than just throw in the card and than install nvidia drivers
Question 2: I'm pretty sure I already know the answer to this but I am going to ask anyway. I know nvidia say that you should have 500w minimum and other vendors are saying 550w for there cards but I know they like to exaggerate the hell out of that maybe for people with a low quality PSU. However I think my XFX Core Edition 550w PSU should be fine. So when I get this card I should have a ton of headroom for overclocking my cpu to hell right? My current card has a 200tdp and this only has 150 so I should be gaining even more headroom and should have no problems in terms of power ever...
Question 3 (General MAXWELL questions): When the hell will the 970 starts selling in the UK? Also so some of these aftermarket people like gigabyte are beefing up the power connections I guess for better overclocking. But it seemed a bit strange to me are TWO 8 pins really nessesary for the 980 which is a TWO 6 pin card??? I thought if they were going to beef it up they would add like a 8 Pin and a 6 pin like they did the the 970 which would be the card I am getting if I go with gigabyte. Also the Strix 970 GPU interests me. Although it only has one 8 Pin??? will it be getting enough power gigabyte has that plus a 6 pin, where they just going overkill???
Gigabyte 980 with its two 8 pins
the gigabyte 970 pretty much looks the same just with a 8 and a 6 pin
Strix 970 with it's one 8 pin
