You can technically mount that into just about any case, by screwing in a standoff or two. So if you happen to find a nice mATX case that you like, you could use that, but then it kinda makes the whole m-ITX situation useless, I think. As far as mini-ITX cases go, they tend to run on the expensive side, and I would recommend saving up about $90 and buying a Bitfenix Prodigy, it is one of the roomier mini-ITX cases and it happens to be pretty easy to build in with dual-slot graphics cards.
