So i'm having some problems with my curent pc build. I saved some money by not buying a gpu. Should i upgrade? I am haveing also software problems with the curent gpu, ALOT of crashes, alot of games don't work.
Curent rig: Fx 8320 3.5ghz, 2x4gb ram from corsair, asrock 970 pro 3 mobo, and GTX260 gpu T_T. I'm also using a 600w power suply from Recom.
I'm thinking of going for the Gtx560 but not so sure...any sugestions?
Hm, ok, PSU seems fine a decent quality, but still a company I've never heard of so take it with a grain of salt.
Try updating your drivers and running ComboFix..If it still crashes after updating your drivers then run ComboFix...If your drivers are already up to date, then redownload them, some files may have been corrupt during the download.
Get the HD 7870 (or 7850) instead of a GTX 560. Should be fine. I have a 7870 from MSI and i really, really like it! Would reccommend MSI if you don't know which brand to buy.
Ran ComboFix, 2 minutes later crashed when playing Far Cry 3, redownloaded every driver, reinstalled all of them, ran combo fix, bam crash again, ran combo fix after crash, crash again. I'm thinking my nvidia isnt that well supported by games..:(
