so im trying to build a beast gaming computer, so what is better cpu, so is there any AMD cpu that will give me better graphics and fps than the i7-3770k? i will also be using the nvidia geforce gtx 770. so if there is a better cpu i could use, please let me know and tell me why it is better! thank you.
I7 4770K :)
For gaming an i5 is just as good as an i7. An i5 is pretty much an i7 without the multithreading. Unless you are constantly doing work on the computer like rendering getting an i7 is just throwing your money away. If you want performance you will feel sink your money into a high end graphics card and a ssd drive.
I would think the i5-4670k might be the better choice for a gaming computer that doesn't wanna cost too much.
What do you have now?
what about the AMD FX-8350? i heard it was pretty good.
if i go with i5, ill be getting the 3570k. its better and cheaper.
right now im playing on an asus gaming laptop, which can get me over 30 fps in all my games.. but i want to make the step up and build a beast gaming pc.
FX8350 is a good choice. performance diffrence between this one and the i7-3770K are realy minimal. i7 performs a littlebit better, in some games, but its also allmost twice the cost, well if i was you i would go with FX8350 asus sabertooth 990FX R2.0 the 150 you safe on the cpu trow in a GTX780. or the new AMD R9-280X
what makes you think a 3570k is better than a 4670k?
Beast is not a verb.
The 8350 is a great choice, but it really depends on your budget. Haswell > Ivy, by the way.
All you need for gaming right now is an i5, although it's sounding like newer games are going to start utilizing more and more CPU cores. An i5 will probably still be just fine, but you could always go for an FX-8350 or i7 if you wanted to make sure you're a little more future proof and prepared for newer games (but like I said before an i5 will still probably have no trouble with them as long as you have a decent graphics card).
As far as raw performance goes, an i5 (3570K or 4670K) and the FX-8350 are about equal, although each has it's own niche that it fills. The i5 is a quad core, and each individual core is more powerful than each individual core on the FX-8350. This means the i5 is going to be better for applications that don't use as many threads, which means the i5 should be slightly better at gaming for right now. The FX-8350 has weaker cores, but it's also an octo-core, which means it's going to be better for heavy multitasking and applications that use more cores like video rendering, streaming, or possibly future games.
The i7 is basically the same as the i5 but with hyperthreading. This means it's going to have four very strong cores with four additional virtual cores. It will be able to handle 8 threads at a time just like the FX-8350, but its cores will be stronger. i7's are the best option for pretty much all applications.
reviews mainly, its cheaper and a well known beast. plus the tek chose it in one of their videos for i think an 1800$ computer.. so i think they know what is best for a computer..
thanks for the information, it has really helped.
this is the internet, not english class. i dont care if it's a verb or not.
Just a matter of how you present yourself. I'm not here to be an idiot, arguing about grammar. The point of my comment was about the CPUs.
I have an i7 4770 not mainly for gaming but it's rips every game up until the GPU bottlenecks it and after seeing fx 8350 in action (or the older i5) I'd recommend you get either the fx 8350 or i5 4670k for gaming, especially the fx 8350 since it will be better in the long run than four measly cores.
what ever is the most expensive, DUH!!!!!!!
if you just gaming amd 8350 is a good choice for the money and many game are being optimised for the extra cores but if you want to go intel a 15 4770k is good but most benchmarks indicate the amd is better
Actually 4770k beats 3960k and 3770k and fx 8350 and even fx 9590. The difference is minimal though. For gaming there's no point in spending more for intel when you have to get the best video card in your budget first. Since the OP already has a good one if you can afford it, going with intel is better, but i5 won't be as good as fx 8350 in the long run.
http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/62166-amd-fx-9590-review-piledriver-5ghz-15.html
