I have spent the last couple of days on this and I have a refined patch, things still are not perfect though as there are cases where the GPU ends up in an unrecoverable state still. I need some feedback from AMD to resolve this.
From 1a723fd375a530781d344a1315c55467ae9dbb1f Mon Sep 17 00:00:00 2001
Date: Wed, 27 Nov 2019 00:32:23 +1100
Subject: [PATCH] quirk: AMD Navi 10 series vendor specific reset (v2)
Signed-off-by: Geoffrey McRae <[email protected]>
drivers/pci/quirks.c | 132 +++++++++++++++++++++++++++++++++++++++++++
1 file changed, 132 insertions(+)
diff --git a/drivers/pci/quirks.c b/drivers/pci/quirks.c
index 44c4ae1abd00..a3325beff5a6 100644
--- a/drivers/pci/quirks.c
+++ b/drivers/pci/quirks.c
@@ -3825,6 +3825,131 @@ static int delay_250ms_after_flr(struct pci_dev *dev, int probe)
return 0;
+ * AMD Navi 10 series GPUs require a vendor specific reset procedure.
+ * According to AMD a PSP mode 2 reset should be enough however at this
+ * time the details of how to perform this are not available to us.
+ * Instead we can signal the SMU to enter and exit BACO which has the same
+ * desired effect.
+static int reset_amd_navi10(struct pci_dev *dev, int probe)
+ const int mmMP0_SMN_C2PMSG_81 = 0x16091;
+ const int mmMP1_SMN_C2PMSG_66 = 0x16282;
+ const int mmMP1_SMN_C2PMSG_82 = 0x16292;
+ const int mmMP1_SMN_C2PMSG_90 = 0x1629a;
+ u16 cfg;
+ resource_size_t mmio_base, mmio_size;
+ uint32_t __iomem * mmio;
+ unsigned int sol;
+ unsigned int timeout;
+ * if the device has FLR return -ENOTTY indicating that we have no
+ * device-specific reset method.
+ if (pcie_has_flr(dev))
+ return -ENOTTY;
+ /* bus resets still cause navi to flake out */
+ dev->dev_flags |= PCI_DEV_FLAGS_NO_BUS_RESET;
+ if (probe)
+ return 0;
+ /* map BAR5 */
+ mmio_base = pci_resource_start(dev, 5);
+ mmio_size = pci_resource_len(dev, 5);
+ mmio = ioremap_nocache(mmio_base, mmio_size);
+ if (mmio == NULL) {
+ pci_disable_device(dev);
+ pci_err(dev, "Navi10: cannot iomap device\n");
+ return 0;
+ /* save the PCI state and enable memory access */
+ pci_read_config_word(dev, PCI_COMMAND, &cfg);
+ pci_write_config_word(dev, PCI_COMMAND, cfg | PCI_COMMAND_MEMORY);
+ #define SMU_WAIT() \
+ for(timeout = 1000; timeout && (readl(mmio + mmMP1_SMN_C2PMSG_90) & 0xFFFFFFFFL) == 0; --timeout) \
+ udelay(1000); \
+ if (readl(mmio + mmMP1_SMN_C2PMSG_90) != 0x1) \
+ pci_info(dev, "Navi10: SMU error 0x%x (line %d)\n", \
+ readl(mmio + mmMP1_SMN_C2PMSG_90), __LINE__);
+ pci_set_power_state(dev, PCI_D0);
+ /* it's important we wait for the SOC to be ready */
+ for(timeout = 1000; timeout; --timeout) {
+ sol = readl(mmio + mmMP0_SMN_C2PMSG_81);
+ if (sol != 0xFFFFFFFF)
+ break;
+ udelay(1000);
+ if (sol == 0xFFFFFFFF)
+ pci_warn(dev, "Navi10: timeout waiting for wakeup, continuing anyway\n");
+ /* check the sign of life indicator */
+ if (sol == 0x0) {
+ goto out;
+ pci_info(dev, "Navi10: performing BACO reset\n");
+ /* save the state around the reset */
+ pci_save_state(dev);
+ /* the SMU might be busy already, wait for it */
+ SMU_WAIT();
+ /* send PPSMC_MSG_ArmD3 with param */
+ writel(0x00, mmio + mmMP1_SMN_C2PMSG_90);
+ writel(0x00, mmio + mmMP1_SMN_C2PMSG_82); // BACO_SEQ_BACO
+ writel(0x46, mmio + mmMP1_SMN_C2PMSG_66);
+ SMU_WAIT();
+ /* send PPSMC_MSG_EnterBaco with param */
+ writel(0x18, mmio + mmMP1_SMN_C2PMSG_66);
+ SMU_WAIT();
+ /* wait for the regulators to shutdown */
+ mdelay(1000);
+ /* send PPSMC_MSG_ExitBaco */
+ writel(0x19, mmio + mmMP1_SMN_C2PMSG_66);
+ SMU_WAIT();
+ #undef SMU_WAIT
+ /* wait for the SOC register to become valid */
+ break;
+ udelay(1000);
+ if (sol != 0x0) {
+ pci_err(dev, "Navi10: sol register = 0x%x\n", sol);
+ goto out;
+out:
+ /* unmap BAR5 */
+ iounmap(mmio);
+ /* restore the state and command register */
+ pci_restore_state(dev);
+ pci_write_config_word(dev, PCI_COMMAND, cfg);
+ return 0;
static const struct pci_dev_reset_methods pci_dev_reset_methods[] = {
{ PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_82599_SFP_VF,
reset_intel_82599_sfp_virtfn },
@@ -3836,6 +3961,13 @@ static const struct pci_dev_reset_methods pci_dev_reset_methods[] = {
{ PCI_VENDOR_ID_INTEL, 0x0953, delay_250ms_after_flr },
{ PCI_VENDOR_ID_CHELSIO, PCI_ANY_ID,
reset_chelsio_generic_dev },
+ { PCI_VENDOR_ID_ATI, 0x7310, reset_amd_navi10 },
+ { PCI_VENDOR_ID_ATI, 0x7312, reset_amd_navi10 },
+ { PCI_VENDOR_ID_ATI, 0x7318, reset_amd_navi10 },
+ { PCI_VENDOR_ID_ATI, 0x7319, reset_amd_navi10 },
+ { PCI_VENDOR_ID_ATI, 0x731a, reset_amd_navi10 },
+ { PCI_VENDOR_ID_ATI, 0x731b, reset_amd_navi10 },
+ { PCI_VENDOR_ID_ATI, 0x731f, reset_amd_navi10 },
{ 0 }
2.20.1
