Hi. I have some quick questions:
Currently i run an old FreeNAS build with a zfs zaidz2 pool with 6x 8TB HDDs.
Those are Geli encrypted and i can’t upgrade the pool or OS. So i thought i make a fresh pool and OS.
Drives are Hooked up to a Dell H200 flashed to IT Mode.
I wanted to add 2 new HDDs and do a raidz1 with 8x8TB (since i have my important stuff backed up somewhere else too)
The 6 x 8TB HDDs are Seagate Enterprise Capacity ST8000NM0065 SAS drives 4KB (native?)
I also bought 1 Toshiba Enterprise 8TB (MG06ACA800E) SATA 512e and
1x WD Whitelable WD80EDAZ-11TA3A0 Sata (idk if 512e or 4KB)
I know i can mix Sata and SAS drives. All are CMR and none SMR. But what i forgot and never fully understood was 512e/4KB compatibility.
Will i be fine with this configuration? Mixing 512e and 4KB (no 512n) Drives?
Drives are currently in a Dell R710 server. I wanted to build a new quieter dedicated NAS.
Thats why i am currently looking at new Case. Desktop or server. I don’t care as long as there are 8-16 drive bays and i can run it somewhat silent.
(I sleep in the next room)
16 bays would be awesome for future expansion. Hotswap would be cool but not really needed if i can easily remove a panel with 2 thumb screws.
If its possible to use ATX or miniATX boards and fullsize ATX PSUs i could use my old ivy bridge PC and would basically only need a case and no new hardware.
Does anyone have a recommendation for good NAS cases? 8-bay up, quiet
Thanks in advance guys
