Hello everyone!
I’m rebuilding my NAS after 5 years. It’s served me well, but I need more storage now, and it’s also time to do some nice upgrades that I couldn’t afford at the time. Here’s the part list:
https://pcpartpicker.com/list/BhTNDx
With that out of the way, I have few questions.
I intend to run one RAIDZ1 with 3 drives and one RAIDZ2 with 6 drives. The main reason for this is that I want to reuse the drives I already have in the system (4 HGST in a RAIDZ2), but I need to keep the data while I reconfigure. Right now the plan is to install 3 of the reds in a RAID5 setup on another computer and transfer the data to those, providing some protection in case of a drive failure during the process. Once the server is set back up with the other 6 drives, transfer the data back, disable the raid and add the other 3 drives. Realistically this is the best plan I have, as it provides some redundancy while doing the data transfer. I’d love to just upload to a cloud service temporarily, but transferring 5tb or so of data up and down just isn’t an option, and I don’t have the storage to do it otherwise.
1- Is this the best way to approach this? Am I overlooking an otherwise easy solution?
Currently, the only part I haven’t gotten for the server is a new PSU. The Seasonic 360w I’ve been using has served me well, but it wont be enough for the upgraded system (adding RAM, 5 HDD, and changing from an i3 to the 1230). In terms of size, the recommendations I’ve seen and best I can figure is that a 650w would likely be the best option. I’ll also potentially be adding another 3 drives in the future, so I’d like to plan for that I’d rather have too much PSU than not enough, even though that means I might miss the efficiency curve by a bit. I’d like to stick with Seasonic, but they’re currently out of stock everywhere. I would like to do this soon, but I also don’t mind waiting. The other unique requirement here is that the PSU needs to be as compact as possible, as I’ll be using a third HDD cage in the case mounted in the alternate position, which limits the space for the PSU itself. The Seasonic units are only 140mm long, which makes them ideal, beyond that I have nothing but good experiences with their products.
2 - Will 650w be enough, or should I go for a 750w? I never want to worry about the PSU after it’s installed, are there any PSU with similar or better performance to a Seasonic gold unit? I’ve seen mention of Corsair RMx and others, but I have no experience with those units. Further, those units would need to meet the “small” criteria.
In regards to growing the amount of drives in the NAS, I’ll likely need to use adapters to have an appropriate amount of SATA power cables. It’s my understanding that not all molex > SATA adapters are created equal.
3 - Will it be ok to run some of the drives off of molex > SATA adapters? Would it be better to use PCI-e > SATA adapters, if such an adapter exists? Should I use SATA splitters? What is the best approach?
Due to a recent scare with a power outage, I’ve also purchased a UPS to provide for a safe shutdown if power is lost for more than 15 minutes. I haven’t configured this on FreeNAS yet, as I’ll be rebuilding and reinstalling soon. I checked NUT and made sure the unit is supported as well, so there shouldn’t be any problems.
4 - Are there any special considerations I should make in regards to making sure NUT works?
I’d like to mirror my OS drive as well when reinstalling, just as another layer of protection. I only have one internal USB port, but I have a USB header on the motherboard I could purchase an adapter for.
5 - Is using a USB header > port adapter acceptable for a mirrored boot drive?
tl;dr
1 - I’m using 3 of the new drives in a RAID 5 to temporarily backup the server while I rebuild the new RAIDZ2 pool. Is this the best way to approach this? Am I overlooking an otherwise easy solution?
Finally. are there any other considerations that need to be made? Anything that I might have missed? I’d appreciate another set of eyes for one last check. Feel free to ask if there are any questions, and thanks for the help!
